22" rims
Hi, I am looking to put 22" rims on my 2003 mountaineer and I was curious if anyone has ever had any issues with rubbing using that size rim. I was considering a 3 inch body lift, but I do not want to spend the extra money on that if I don't need to. 20" rims look too small in the wheel well.
If anyone can help I would appreciate it. Thanks, Tony |
I had 22's on mine with no issues. no lift required. most cars can fit a 22. You can put 24s on it with no problem with a 30 series tire. That is what i have on mine now. no need to lift at all.
285s
Can I fit 285s front and back or at least the back w out rubbing?
WIth the stock height, might raise the front inch or two to level the car out, would that even help to fit 285s |
