302 blocks
the block you are wanting is the same thing as any other 302. only difference with the 302 you want compared to a Grand Marquis is that yours has a HO cam, HO upper and lower intakes, and cylinder heads. any 302 from 1986 or newer will work as long as you put your stuff back in the block
