accelorator issues 99 Mountaineer
Old Aug 11, 2007 | 03:46 PM
hhunni08's Avatar
My Dad has a 99 Mercury Mountaineer that when started idles fine but when put into gear kills the engine. Replaced the mass air flow sensor still has problem. He took it to a mechanic to put on the computer but the computer can not read any codes. Can anyone help?? The engine type v-6, and is a 4wd.
Old Jan 1, 2008 | 01:47 PM
JedClampett's Avatar
Might want to check the IAC; clean or replace might do the trick.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
urchinTracker();
Old Jan 18, 2008 | 11:27 AM
IAC = Idle Air Control Valve
TPS = Throttle Position Sensor
sounds to me like this is the problem. i have seen weird occurances where a vehicle low on transmission fluid causes this also. the TPS might be acting up, but that is usually acts up when you are driving and not at idle speed. here is a site to help identify it and the cleaning procedure...
http://www.explorer4x4.com/wheels_offset_backspace.htm
keenan
Mar 1, 2009 01:40 AM
OutlawdSVT
Feb 9, 2008 11:26 PM
OutlawdSVT
Feb 8, 2008 08:39 PM
