-   -   door locks (https://www.mercuryforum.com/forum/mountaineer-17/door-locks-2378/)
mikem5063 Jan 9, 2009 09:27 AM
has anybody had a problem with the automatic door locks? I have an ''02 Mountaineer that shows door ajar and the interior lights stay on. when this happens the main switch in the drivers door won''t do anything but the passenger door switch still works. I just had a big fiasco with the heater control and still haven''t resolved that yet. I know it sounds like the main switch but that''s what I thought about the heater and 55 dollars later it still don''t work. any suggestions would be appreciated.
slymer Jan 9, 2009 08:07 PM
check the door light switch. make sure the nut is tight on it. if that doesn''t help, it may need to be replaced.
mikem5063 Jan 11, 2009 07:02 AM
I''ll give it a try thanks
ronklein57 Jan 18, 2009 12:44 PM
spray wd-40 liberallyon all latches including rear hatch.....also spray in door lock on drivers side door.....worked well for me....good luck
