-   -   Keyless Entry Code module location (https://www.mercuryforum.com/forum/mountaineer-17/keyless-entry-code-module-locatin-1022/)
Reborn Apr 25, 2007 11:16 PM
I just purchased a 2005 Mountaineer with 15k miles!!!. There was no keyless entry code in the manual ora glove box card. Dealer does not know the code either. Where can I find the module that has the 5 digit code on it? Of course the dealer doesn't know this either. Any help will be appreciated. Thank you in advance.
bkbigf0ot Apr 26, 2007 06:54 PM
Try calling the Mercury. their costumer service should tell you the numebr if you give them the VIN#. Good luck
Reborn May 17, 2007 08:35 AM
Sorry bkbigfoot your answer does not work, because anyone can get a VIN number a get your code. I called around and dealers was willing to electronically connect a device to my Mountaineer to find the code for around $75-$125. Do not be fooled by this big lie. Here is the real answer and it is FREE!!! A user name Rakel posted this and it works. Thanks Rakel [img]smileys/smiley4.gif[/img]
Open the right/rear door. Fold the right/rear seat down. Carefully pull the trim panel where the right/rear seat belt pivot/height adjuster is housed. Once removed, pull the trim panel below that in order to expose the Vehicle Security Module (the module that controls the electronic locking system for your vehicle) that has the three electrical connectors plugged into it. The connectors are coloured green, grey, and blue. On the module there is a label with the engineering number similar to 5L2T-15K602-EA. You will also see FIVElargenumbers. Those FIVE large numbers are your Keyless entry keypad code. Once you know your kepad code, you can test its operation by first entering the FIVE digit kepad code to unlock the driver door, and then pressing the 3/4 button within 5 seconds to unlock ALL doors. Pressing the 5/6 button within 5 seconds after entering the code will unlock the lifgate glass. Pressing the 7/8 and 9/0 buttons simultaneously at any time will lock ALL doors. Hope this helps.
famsord May 30, 2008 08:58 AM
[img]smileys/smiley17.gif[/img]Thanks a bunch!!! I was able to get to keypad code on my '04 Mountaineer I bought used.
mmoreau Jul 26, 2008 11:44 PM
I just bought a 2002 Mountaineer, I will be trying this tomorrow for sure. Thanks!
jason sereiko Aug 20, 2008 11:15 PM
great job reborn!![img]smileys/smiley1.gif[/img]now that is great help. keep up the good work and welcome to the forum
m420 Aug 24, 2008 05:42 PM
Hey reborn.
I had the same problem with my 03 mountaineer. one day I was replacing my factory subwoofer and found the code. you have to take off the back passanger side panel. It will be on a sticker on a mod. close to the pass side back door.
hope this helps
blaze973 Sep 16, 2008 03:24 PM
some pictures would help im having some trouble still finding where all this is
cbrooks Jan 20, 2009 02:59 PM
Many thanks rebornand Rakel, I appreciate it, just bought an 04 and the card i got with it had the wrong code!!, was driving me nuts, I had tried resetting it and everything else and nothing worked. found the code on the security module and it worked great, changed it to the one on the wallet card that came with it that was wrong in the first place so I won''t lose it(I will anyways) Thanks again.
mamouton Apr 2, 2011 05:02 PM
Thanks that worked like a champ. I should have taken photos but it is easy I didn't feel the need.
