Noise when I turn left
Old Jun 12, 2009 | 09:58 PM
propack's Avatar
Default Noise when I turn left
I have 2002 Mountaineer. It has the normal rear end noise. But now when I steer left @ speeds above 25mph and up it makes noise that almost sounds like bad wheel bearings. Just replaced the front wheel bearing, didn't help. Check all the bushings they all seem to be ok. Could it be the carrier bearing are bad?
Old Jun 13, 2009 | 01:14 PM
conan312's Avatar
what about the other wheel bearing?
Old Jun 14, 2009 | 04:30 PM
propack's Avatar
All the wheel bearings seem to be fine.
Old Jul 11, 2009 | 04:36 PM
walnuts911's Avatar
I had the same problem when i turned right, i had to get the ball joints replaced before i could get my tires alighned and i asked my mechanic. it turned out that the stabilizer was broken in half but still LOOKED fine, after those repairs were done, the noise went away.
Old Jul 14, 2009 | 10:44 PM
conan312's Avatar
Have you checked everything that caused the noise last time?
Old Aug 1, 2009 | 10:31 PM
pgreenleaf62's Avatar
Default noise turning left
this may sound stupid, but check your lugnuts torques. make sure there isnt any rust where the wheel seats to the axel. Check your cv shaft too, usually clicks when bad but ive seen them come into the shop that hummed or hissed like a bearing. Check the whole front end for play, especially the tierods. Make sure your tire pressures are all dead-on, if the whole front end is tight and all of those things check out, id get into the stearing box and all of the other steering linkages.
Is this under warranty???
Hetron
Mar 6, 2012 09:36 PM
walnut777
Mar 2, 2010 10:31 AM
rocco08
May 15, 2009 07:37 PM
jason sereiko
May 28, 2008 07:55 PM
luy123
Jun 10, 2006 09:34 PM
