-   -   Removing rotors??? (https://www.mercuryforum.com/forum/mountaineer-17/removing-rotors-3283/)
minitrkingking Sep 19, 2009 05:30 PM
Removing rotors???
I have a 99 Mercury Mountaineer AWD with horrible brakes. I have removed the park brake cable, calipers and everything else but I can't get the rotor off. It won't budge, I think the park brake pads have grooved the inner rotor and it won't come off the lip now? How can I get these off? Thanks for the help
minitrkingking Sep 19, 2009 05:34 PM
I just tried to rotate the rotor and tap/pry it off as it turns but nothing, not even a little:(
conan312 Sep 20, 2009 03:39 AM
You need to free it up by really wailing on it with a decent sized hammer. Hit it between the studs but WITHOUT hitting them. If the rotors are being replaced then hit them anywhere. Leftside then right. Upper part then lower. Just don't try to hit them from behind to get them off. Don't worry, they will free up.
