I was driving on a rainy day, car runs fine then just stalls with no noises. I took it to a ford garage and they said they did not know what was wrong to try a icm. I changed that and the coil pack and still no start(fire). The car has 65000 miles and is a good car. I cannot find a manuel that tells me what I should check hot key on or hot at cranking. 480 dollars in parts and still trying-need help... It is a 2.5 engineEdited by: larry stone
If the engine just stalled out at speed without any warning or prior probs, I would try checking the crank sensor.
Thanks Again, Larry |
Sounds like you just need to replace the MAF sensor now. Then reset the comp by taking off the the neg. battery terminal for a few mins. Let me know.
