98 mystique LS overheating
Old 05-18-2018, 01:50 PM
D619's Avatar
Default 98 mystique LS overheating
i finds myself in a situation where my car overheats when I traffic or a standstill. I replaced the radiator and reservoir tank (got the 4 cylinder version since I was told it worked). I have some smoke that comes out from under the hood when it gets in the A in the NORMAL writing on the temp guage. I use to be able to hear my fan come on but either it’s quieter or not working. I literally have no way of checking what it could be. Anybody have recommendations or what it could be? Thanks in advance!
Old 05-20-2018, 12:27 PM
Your temperature should not get to the "A" in "Normal"--.
Check for coolant leaks around the Water Pump area. If it's leaking, it MUST be replaced. Get a Motorcraft water pump -- the cheap ones don't last !!
Check to make SURE that the electric fan comes "ON" when engine gets to the "A".-- if the fan doesn't come on, it may be a fuse or the fan motor has conked out.
If the electric fan is working, you will need to flush the cooling system and install the CORRECT Motorcraft thermostat.
Fill with 50/50 mix of ethylene glycol and distilled water.
Your temp gauge should point between the "R" and the "M" when the engine is at operating temperatures.
4-cylinder engine = Water Pump - Motorcraft #PW 368 --- Thermostat - RT1150
V-6 engine = Water Pump - Motorcraft #PW 563 --- Thermostat - RT1131
Part available at RockAuto.com
Old 01-12-2019, 11:59 AM
Tim Albanese's Avatar
Default Overheating
Ok so i think my mistique has been running hot. My guage usually points between the o and the r. But recently it sits between r and m sometimes on m all the way is this overheating?
D_Rock87
04-22-2010 11:02 PM
ireadrules
08-13-2007 07:39 AM
mfox7
04-11-2005 08:39 PM
Quick Reply: 98 mystique LS overheating
