Heater Fan
Old 01-24-2008, 10:00 AM
1995 Mystique 2.0 liter - When using my heater or A/C the fan will run fine with the fan switch on the ON or Low position, if turned to medium or high positions it stops working. Does anyone have an idea why this happens?
Thanks for any help.
Edited by: 87_Crown_Vic
Old 01-26-2008, 01:57 AM
Your Mystique has two fan switches. One for high speeds, and one for low speeds. You need a "High Speed Fan Switch", for it does not work at the two higher speeds. If it were the two lower speeds that did not function, you would need a "Low Speed Fan Switch". Available at any part store. You'll pay alot more at the Ford dealer. P.S. It's not hard to replace.
Old 02-01-2008, 07:33 PM
I am having the same problem on my 1995. I have only one control switch on the dash that has 4 settings, the 3 and 4 settings (medium and high) don't work. Would replacing the dash control switch fix it or is it a fuse or relay?
Thanks for any help!
< =text/>
_uacct = "UA-939292-45";
urchinTracker();
Old 02-03-2008, 04:16 PM
I don't think there are two seperate fuses for the fan motor, so I would say you too, need a High Speed Fan Switch. But it doesn't hurt to look for a second fuse, for there are two fan switches. Let me know.
MGM46
01-03-2014 10:02 PM
tombags
02-25-2012 06:41 AM
Stray Dogs
05-19-2006 08:42 AM
Coachkey22
03-21-2006 08:49 PM
PiTcReWfLuNkY
07-16-2005 10:32 AM
Quick Reply: Heater Fan
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
