Seatbelt Torque Size
Hey, I'm trying to replace my seatbelt assembly, and was wondering if anyone knew the torque size needed to remove the large black bolt holding it in?
I have a 1998 Mercury Mystique. Thanks! |
you can get a set of torx bits at autozone that ranges from 35 to 70 I think it is. one of those should fit it. If I remember right, it should be a T45. Get the sales rep to help you out and you can check them against the car while you're there to make sure. (pick your parts store of choice for that matter, I just happen to have an autozone on the way home from work that I use most of the time)
Originally Posted by slymer
(Post 11567)
Thanks slymer! |
| All times are GMT -5. The time now is 09:24 AM. |
