Turn Signal Problems
My turn signals will not flash but my emergency flashers work. I was told that this is most likely the turn signal flasher. Where is the turn signal flasher on a 2000 Mercury Mystique? I know its most likely by the fuse box under the dashboard but specifically which fuse is it? I couldn't get a mystique repair manual from the auto parts store because they were all sold out so I ordered one online. I'd really like to be able to fix this problem now rather than waiting for the book, if anyone can help I'd greatly appreciate it.Edited by: dc3886
I found it under the steering column. If you are having the same problem just take all of the plastic off the steering column and you'll see the flasher there. All you have to do is unplug the old one and plug in the new one. Its a very easy fix once you know where it is.</>
< =text/>
_uacct = "UA-939292-45";
urchinTracker();
</>Edited by: dc3886
< =text/>
urchinTracker();
