My car has been making an awful high pitched whistling sound coming from somewhere under the hood. It seems to be anytime the car is on, regardless of if I am accelerating or not. When I am idle, it is really loud. I just want some opinions on what it is before I break down and take it in to the shop. Thanks. |
I had a jeep do that it grove me nuts it turned out to be the distributer alack of oil on the shaft? I also had a fan belt that was too tight do that. and a idle polly that was dry. A vacume leak . |
Is the vehicle a 4 or 6 cylinder? And does it go away when it warms up?
it is a 4 cylinder and no it does not go away when it warms up. it's really bad today |
Does the vehicle have any stalling problems? |
Check belt tensioner on 2.0 4cyl. depending on mileage probably still under warranty.
check the belt or belts for tension. if they're ok a water pump , alternator, or even a power steering pump will whine when they are starting to go.
