-   -   1998 Sable LS Keyless Programming (https://www.mercuryforum.com/forum/new-member-area-8/1998-sable-ls-keyless-programming-1199/)
caddykm Aug 16, 2007 08:14 AM
[img]smileys/smiley2.gif[/img]I have a 1998 sable LS 3.0l 24v duratec which has a new motor in it due to a cam shaft snapping at 75,000 milesbut shes running great again. I ran over my remote with my f-350 and it did not fair to well. I got a new one and I was wondering if anyone knows how to program it? Do you go through the same steps as the 02 sable? Thanks for any help. Dealers are way to proud of what they offer these days.
92Mercury Aug 16, 2007 09:08 PM
97-24-13, Publication Date: NOVEMBER 24, 1997
http://www.v8sho.com/images/TSB/Image99.gif
FORD:
1993-97 PROBE, THUNDERBIRD
1993-98 CROWN VICTORIA, TAURUS
1994-98 MUSTANG
1995-98 CONTOUR
1997-98 ESCORT
LINCOLN-MERCURY:
1992-98 CONTINENTAL
1993-97 COUGAR
1993-98 GRAND MARQUIS, MARK VIII, SABLE, TOWN CAR
1995-98 MYSTIQUE
1997-98 TRACER
LIGHT TRUCK:
1992-98 ECONOLINE
1993-98 EXPLORER
1994-96 BRONCO
1994-98 F SUPER DUTY, F-150-350 SERIES
1995-98 RANGER, WINDSTAR
1996-98 VILLAGER
1997-98 EXPEDITION, MOUNTAINEER
1998 NAVIGATOR
This TSB article is being republished in its entirety to include other models and revise procedure.
ISSUE:
The Remote Keyless Entry (RKE) system may be inoperative. This may be caused by several different items.
ACTION:
Refer to the following Diagnostic Chart and text for tips on servicing customer concerns with the RKE system.
NOTE:
WHEN SERVICING THE RKE SYSTEM, THE VEHICLE SHOULD BE IN THE FOLLOWING STATE: THE IGNITION SHOULD BE IN THE OFF POSITION AND ALL LIGHT SWITCHES MUST BE IN THE OFF POSITION. ISOLATE THE VEHICLE SO THAT NO RKE TRANSMITTERS ARE OPERATED WITHIN AN 18 METER (60 FT) RADIUS.
http://www.v8sho.com/images/TSB/Image100.gif
http://www.v8sho.com/images/TSB/Image101.gif
http://www.v8sho.com/images/TSB/Image102.gif
http://www.v8sho.com/images/TSB/Image103.gif
http://www.v8sho.com/images/TSB/Image104.gif
Figure 1 - Article 97-24-13
http://www.v8sho.com/images/TSB/Image105.gif
Figure 2 - Article 97-24-13
http://www.v8sho.com/images/TSB/Image106.gif
Figure 3 - Article 97-24-13
http://www.v8sho.com/images/TSB/Image107.gif
Figure 4 - Article 97-24-13
http://www.v8sho.com/images/TSB/Image108.gif
Figure 5 - Article 97-24-13
http://www.v8sho.com/images/TSB/Image109.gif
Figure 6 - Article 97-24-13
http://www.v8sho.com/images/TSB/Image110.gif
Figure 7 - Article 97-24-13
http://www.v8sho.com/images/TSB/Image111.gif
Figure 8 - Article 97-24-13
REFERENCE PROCEDURE STEPS FOR RKE PROGRAMMING
A. Cycle ignition from OFF to RUN or ACC eight (8) times within 10 seconds, ending in RUN or ACC. All doors will lock then unlock to confirm programming mode. Press any button on 1st remote transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming.
NOTE:
ESCORT/TRACER WITH SINGLE DOOR REMOTE ENTRY SYSTEMS WILL CYCLE THE DRIVER'S DOOR LOCK ONLY.
B. Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in left rear quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). The door locks will lock then unlock to confirm programming. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
C. Enter 5-digit permanent entry code into the keyless entry keypad. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate successful programming. Press any button on 2nd transmitter (up to 4 transmitters total possible) within 5 seconds of previous transmitter (if keypad light goes out before all transmitters are programmed, the process must be repeated). Press the 7/8 and 9/0 buttons simultaneously on keypad to exit program mode.
D. Cycle ignition from OFF to RUN or ACC five (5) times within 10 seconds, ending in RUN or ACC. All doors will lock then unlock to confirm programming mode. Press any button on 1st remote transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming.
E. Enter vehicle, close and lock all doors. Insert and remove key from ignition six (6) times within 10 seconds. Instrument panel lights will flash to indicate original code has been erased. Turn ignition to the ACC position. Press LOCK button on 1st transmitter. Instrument panel lights will flash to confirm programming. To enter additional transmitters, unlock, then lock the doors using the power lock switch located on the driver door. Press LOCK button on additional transmitter (up to 4 transmitters total possible). Instrument panel lights will flash to confirm programming. Turn ignition to OFF.
F. Turn ignition to RUN or ACC. Jump pins in programming connector located at the base of the steering column for entire programming mode procedure. All doors will lock then unlock to confirm programming mode. Press any button on the 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming. Remove jumper used with programming connector.
G. Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in right rear quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. The door locks will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming.
H. Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located behind glove compartment. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. The door locks will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming.
I. Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located behind glove compartment. The horn will chirp to confirm programming mode. Press any button on 1st transmitter. The horn will chirp to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). The horn will chirp to confirm programming. Turn ignition to OFF. The horn will chirp one last time to indicate end of programming mode.
J. Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located at the base of the steering column. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. The door locks will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming.
K. Cycle ignition from OFF to RUN or ACC four (4) times within 3 seconds, ending in RUN or ACC. All doors will lock then unlock to confirm programming mode. Press any button on 1st remote transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter within 7.5 seconds (up to 4 transmitters total possible). Turn ignition to OFF or wait 7.5 seconds. All doors will lock then unlock to confirm programming mode.
L. Diagnostic method of programming transmitters is as follows:
1. Choose Service Bay Functions from the service function card.
2. Choose Driver Door Module (DDM).
3. Choose Key Fob Programming.
4. Press any button on the remote entry transmitter.
5. Choose Fob 1, 2, 3, or 4 and press Store.
6. Repeat Step L4 for additional transmitters.
7. Press Cancel to get out of menu (you may have to press Cancel twice).
NOTE:
FOR FUTURE VEHICLE STRATEGIES, THESE PROGRAM PROCEDURES WILL BE COMMONIZED.
http://www.v8sho.com/images/TSB/Image112.gif
http://www.v8sho.com/images/TSB/Image113.gif
http://www.v8sho.com/images/TSB/Image114.gif
http://www.v8sho.com/images/TSB/Image115.gif
WARNING:
l WHEN PROGRAM MODE HAS BEEN ENTERED, ANY TRANSMITTER FUNCTIONED WITHIN 30 METERS (98 FEET) OF THE VEHICLE CAN GET PROGRAMMED TO THAT VEHICLE AND IN THE PROCESS ERASE OUT ALL PREVIOUSLY STORED TRANSMITTER CODES.
l TYPE 2 AND TYPE 3 TRANSMITTERS ARE INTERCHANGEABLE.
l TYPE 1, 7, AND 8 ARE INTERCHANGEABLE.
l TYPE 5 AND TYPE 6 ARE INTERCHANGEABLE.
l TYPE 4 IS UNIQUE AND CANNOT BE USED ON ANY OTHER VEHICLE.
OTHER APPLICABLE ARTICLES:
² 93-24-12
SUPERSEDES: 97-19-8
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES: 112000, 203000, 203200, 204000, 205000
caddykm Aug 17, 2007 06:49 AM
Thanks 92mercury that was so much help.
92Mercury Aug 17, 2007 07:54 AM
You're welcome. Thanks for acknowledging.
Greetings!
