-   -   AX4S Problems 94 sable (https://www.mercuryforum.com/forum/new-member-area-8/ax4s-problems-94-sable-99/)
Windzer Feb 20, 2005 12:19 AM
What they dont tell you could save
you from getting a new transmission.
http://www.transmissionspecialty.com...ts/96201-01K.h tm
Follow this link to learn more.
Windzer Feb 22, 2005 11:22 PM
I have a 94 sable with the ax4s
when i stop the car at a stop sign
the trany doesn't reengage until i
tap the gas then it clunks in gear
any ideas?
Windzer Feb 24, 2005 01:07 PM
Going to check the tps . Has something to do with the Turk converter lock up.
Windzer Mar 1, 2005 12:29 AM
Boost Valve,Forward Control Valve,Servo Tube Bracket,Low Radius Relief Valve,Bypass Clutch Control Valve,Retainer clips, The Surecure
Maybe that will fix my stuped transmission
link http://www.transmissionspecialty.com/parts/PDF/SC-AXOD-E.pdf
Windzer Mar 29, 2005 09:37 PM
Well this is the low down 2256.20 wow but this is the list
1 assembly set-ls-w/.070 intermediate steels(b) 217.11
1 filter-2nd design(b)==================15. 41
1 band-overdrive(b)= ================ 15.83
1 band overdrive(b) ?================= 20.03
13 fluid(b) ;&nbsp ; ; ; ; ; ;==================== 68.25
7.5 labor(rr)(b) =====================525.00
8.4 labor(r)(b) ;===================== 588.00
1 torque converter====================3 29.00
1 chain-drive assembly(chainstre tched)====99.43
1 piston-forward clutch(was cracked)=======21.00
1 planet-ary(was comming apart)=========55.00
1 solenoid-L/u (milege)=========51.00
1 solenoid-pressure control&nbsp ; ; ; ; ; ;"======== 51.00
3 solenoid-shift ;&nbsp ; ; ; ; ; ;" ;&nbsp ; ; ; ; ; ;=====136.08
1 sprag clutch-low clutch sprag ;&nbsp ; ; ; ; ; ;======45.00
1 roller clutch-direct clutch roller ;&nbsp ; ; ; ; ; ;======31.00
1 vb kit-shift kit-transgo(updated Vbody lubeholes)==66.00
tax====================================61. 00
cupone (100.00)cupon from web== -139.00
total parts========================= ==1221.14
labor ;&nbsp ; ; ; ; ;==========================974.00
total ;&nbsp ; ; ; ; ; ========================== 2256.20Edited by: Windzer
Patrick Mar 31, 2005 02:22 PM
is it fixed now??
Windzer Apr 1, 2005 12:10 AM
Yes a ok
