Can somebody at least post a response?
I am getting the feeling nobody is here, lol.
Can somebody here please post a response? |
Remember the old song --
"There Ain't Nobody Here But Us Chickens!" Anyways, this site has been hi-jacked by a bunch of foreign pimps. There doesn't seem to be anybody watching the store. |
Oh really. I guess that explains the lack of any responses. Thanks for letting me know. Why do you say foreign pimps?
That is a song that is new to me...but I just googled it ... would seem to fit, lol ... |
https://cimg9.ibsrv.net/gimg/www.mer...000d37d7e9.jpg
https://cimg6.ibsrv.net/gimg/www.mer...2c1eb9f403.jpg Yo, Mnalep !! Not many peeps come here -- the thread has been hijacked by "Escort Services" (pimps) from foreign lands. I'm presently the most active member, but I don't come here every day (sometimes only weekly). Thanks-a-ton for the U-Tube post -- Brought back old memories from when I was a kid during WW2. You got a Mercury !?? If so, what year and model ?? As my handle suggests, mine is a '95 MERC -- Grand Marquis GS -- major restoration. -- set up for long-distance, hi-speed touring through the deserts and mountains of the American Southwest... 1995 Grand Marquis GS Restoration. Engine is basically stock, with no internal modifications. Items marked with "#" are/were available for purchase at Amazon.com. Intake Air Box Snorkel removed - cool air is ducted from forward of the engine compartment. # K&N *33-2272 Re-usable Air Filter. # Bosch *69128 Electric Fuel Pump. # Bosch *68015 In-Tank Fuel Filter. # Motorcraft *FG800 In-Line Fuel Filter. # Mallory *4213 Adjustable Fuel Pressure Regulator -- 35 psi. @ 800 rpm. # Bosch Series 3 - 19 lb. Fuel Injectors. # Bosch *09725 Mag-Core Ignition Wires. # Bosch *9605 Double-Iridium Spark Plugs. # Motorcraft *PW357 Water Pump. # Motorcraft RT 1103 Thermostat. # Motorcraft *YB541 Fan Clutch. # Bosch *15717 Oxygen Sensors (4). # Bosch *SR7533N Starter. # Bosch *AL7537N 130-Amp Alternator. # Gates *K060980RPM RPM Series Serpentine Belt. # Gates *38386 DriveAlign Belt Tensioner. # Motorcraft *KM2973 Upper Radiator Hose. # Motorcraft *KM2969 Lower Radiator Hose Assembly. # Dorman *624-107 Electric Fan Assembly. # Motorcraft *YC166 Air Conditioning Compressor. # Four Seasons *38904 Severe Service Orifice Tube. # Behr *351214031 PAO Compressor Oil. # Dual Exhaust - Walker *40383 H-pipe. # MagnaFlow *18134 - 2" x 3.5" x 21" Glasspacks. # Walker Tail Pipes - *46761(right side); *46789 (left side). # Superior *28-6201 2 1/2" x 6" Stainless Steel, Slant-cut Exhaust Tips. # B&M *70268 13,000 b.t.u. Transmission Cooler Kit. # B&M *40264 Transmission Shift Improver Kit. # B&M *80250 Transmission Drain Plug Kit. # XPERT Performance Cast Aluminum Differential Girdle. # LubeLocker *LLR-F880 Differential Gasket # Energy Suspension *4.3150G Urethane Control Arm Bushings (upper & lower) # MOOG Greasable Ball Joints, Tie Rods, Idler Arm. (front) # MOOG *K8853 Greaseable End Links (front). # Motorcraft *HUB3 Wheel Bearing Hubs (front) # ADDCO 1 1/4th" Front Anti-Sway Bar, with Energy Suspension Greaseable Urethane Bushings. # ADDCO 1" Rear Anti-Sway Bar, Urethane Bushings. # Energy Suspension End Links with Urethane Bushings (rear). Eclipse Brake Calipers (front & rear). # ACDelco Drilled & Slotted Brake Rotors (front & rear). # Motorcraft Police Brake Pads -- BRSD678 (front) & BR107B (rear). # D.O.T. 4 Hi-Temperature Brake Fluid. # 98T (118 mph) Goodyear Assurance ComforTread Touring Tires. 5 "Italian Lace" 15" alloy wheels (includes spare). # 9006 (Lo-Beam) Cougar Motor 6000k L.E.D.s. # 9005 (Hi-Beam) Cougar Motor 6000k L.E.D.s. # HELLA *980860801 Daytime Running Lights. # Dorman *38445 Door Strikers. # Garmin 66LMT Navigation. Limo-Tinted Windows. Custom Headliner by "Hot Rod Interiors", Glendale, AZ. Dual Exhaust system welded up at "MufflerMasters", Avondale, AZ. ** All parts installed on this vehicle are certified and guaranteed to be GLUTEN-FREE !! *** No animals were harmed during this vehicle restoration. Quarter-Mile = 16.2 sec. @ 88.6 mph. |
