I recently purchased a 1993 grand marquis with 62000 miles and is mechnically sound, I am looking for more horse power performance, is it expensive to convert to a dual exhaust system or am I better just going with a high flow muffler swingle outlet. Hello everyone
yes it is expensive, but you will see far more gains than you will with a dual outlet muffler.
I have a 1989 Cougar LS. I need to know where I can find a dual exhaust catback system. I hate the system that is on it right now it robs power. It has the dual out from manifold which goes into a dual inlet to single muffler. |
but in many areas, adapting your exhaust system to a true duals etup is against emissions laws
ONLY if you bypass cats. If you install 2 cats for two pipes ypu will be fine. |
Grand Marquis Dual Exhaust System
https://cimg4.ibsrv.net/gimg/www.mer...d031e0f9c4.jpg
Walker 2" Dual Exhaust https://cimg2.ibsrv.net/gimg/www.mer...d93489e921.jpg Custom Exhaust Exits. Dual exhausts on your '92 -'95 Grand Marquis will ad 20 horsepower, according to Ford Motor Co. I bought the parts from Amazon, installed them myself to get a proper fit, and then had it all welded up at MufflerMasters, Avondale, AZ. Walker H-Pipe - Part #40383 MagnaFlow Glasspacks. - Part #18134 Walker Tailpipes - Part # 46789 - Left Side. Part # 46761 - Right Side Superior *28-6201 - 2 1/2" x 6" Stainless Steel, Slant-cut Exhaust Tips Stainless steel Bolts, Nuts, & Lock Washers were used to attach H-Pipe. H-Pipe Gaskets (2) = Fel-Pro #60924 |
hi new member here i have a 96 grand marquis gs
Can anyone help me out with the best way to add power to this motor and bolt on i can get ram air or cold air intakes ECUs or exhaust? thank you
