Running issues with 2015 40 hp mercury
I have a 2015 mercury 40 hp efi tiller outboard. It’s ran fine up until the last few months. I fire it up and it will run at wot for around 10 minutes then start to bog down and lose power. I can then restart it and it will run fine for a little longer than persist with the same problem. I’ve replaced the fuel lines, a whole new tank, spark plugs, cleaned out the vst it was full of nasty fuel sedamint at the bottom but still ran bad after cleaning.
You need to go to a MERCURY OUTBOARD MOTOR site.
Mercury (Ford Motor Company) doesn't make cars any more. https://cimg4.ibsrv.net/gimg/www.mer...b861d6065b.jpg '95 MERC at Flaming Gorge, Utah. Ford did/does not make outboard motors. Good Luck !! |
| All times are GMT -5. The time now is 05:04 AM. |
