Off Topic A place for you car junkies to boldly post off topic...
How a inverter air conditioning system communicate
Old Dec 4, 2023 | 07:11 PM
AndreLloyd's Avatar
Default How a inverter air conditioning system communicate
Hi,
I had a question that how does outdoor unit and a indoor unit of a air con communicate using a signal wire.
So , i hooked the communication wire to an oscilloscope to visualise it . I have attached signal image document.
It is same as of UART. So i hooked it to the serial pin of the ardunio and tried to decode it by changing baud rates, but it did not work, nothing got print to it.
So i decided to decode it manually. By browsing i found that the pulse with duration
32+88 is a 1 and pulse with duration 32+48 is a 0 and the long pulse the gap between the data stream.
I decoded it the format of binary as 1 and 0.
But I found that every 3 minutes it changes the
Pattern.
So my question is can a ardunio do it for me??
If yes!!
how should i program??
Old Dec 5, 2023 | 04:32 AM
merleahoms's Avatar
they have not provided any details about it. instead then have only provided the wiring diagram of the whole unit.
James Perrino
Dec 15, 2019 03:52 PM
vilar
Jun 26, 2013 07:26 PM
Bob-18854
Jul 10, 2008 07:55 PM
