-   Off Topic (https://www.mercuryforum.com/forum/off-topic-9/)
-   -   How a inverter air conditioning system communicate (https://www.mercuryforum.com/forum/off-topic-9/how-inverter-air-conditioning-system-communicate-14238/)
AndreLloyd Dec 4, 2023 07:11 PM
Hi, https://emoji.discourse-cdn.com/twitter/wave.png?v=12https://emoji.discourse-cdn.com/twitter/wave.png?v=12
I had a question that how does outdoor unit and a indoor unit of a air con communicate using a signal wire.
So , i hooked the communication wire to an oscilloscope to visualise it . I have attached signal image document.
https://europe1.discourse-cdn.com/ar...2_690x189.jpeg
It is same as of UART. So i hooked it to the serial pin of the ardunio and tried to decode it by changing baud rates, but it did not work, nothing got print to it.
So i decided to decode it manually. By browsing i found that the pulse with duration
32+88 is a 1 and pulse with duration 32+48 is a 0 and the long pulse the gap between the data stream.
I decoded it the format of binary as 1 and 0.
But I found that every 3 minutes it changes the
Pattern.
So my question is can a ardunio do it for me??
If yes!!
how should i program??
merleahoms Dec 5, 2023 04:32 AM
they have not provided any details about it. instead then have only provided the wiring diagram of the whole unit.
