-   -   1995 Mercury Sable Door Panel Removal (https://www.mercuryforum.com/forum/sable-13/1995-mercury-sable-door-panel-removal-235/)
jdawg38 Jul 3, 2005 06:15 AM
i want to upgrade my front speakers and i am having trouble with removing the door panels, any suggestions or schematics?? thanks jeff
Sablefreak Jul 16, 2005 11:18 PM
If you are careful you can remove it with a flat head screwdriver after unscrewing all the screws you can see on the door (check around the edges of the panel) then wedge the flathead screwdriver inbetween your door and the door panel and pry it off using the screwdriver and your fingers ( use your fingers as much as possible when you pry it up so you don't put all the force in a small concentraited areah and break your door panel) then you can remove the speaker brackets with the speakers attatched, they are 6 1/2", take out the screw holding the speakers to the brackets, and pry the speakers off (they are glued on) and simply screw the new ones on. You will need to splice thespeaker wires,and I don't know what the wiring code is, butyou can find it on the web. Line up the clips on the door panel with the appropriate holes and pop the panel back on and your set!
jdawg38 Jul 17, 2005 02:36 AM
thanks i had purchased a door trim removal tool from crutchfield.com along with the new speakers, it was only 10 bucks but it was worth it, i only broke one clip while removing both doors. i got the new speakers in, which are a tight fit, could only get three screws in with each one but the speakers sound great. they were like 70 bucks and def make a huge difference
