-   -   1998 Sable (https://www.mercuryforum.com/forum/sable-13/1998-sable-21/)
BFGRAVES Oct 5, 2004 11:46 AM
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNABLE="on">
<T>
<TR height="100%" width="100%" UNABLE="on">
<TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNABLE="off">my heater only blows cold air. the heater hoses are warm going to the heater core. any suggestions</TD></TR>
<TR UNABLE="on" hb_tag="1">
<TD style="FONT-SIZE: 1pt" height=1 UNABLE="on">
<DIV id=hotbar_promo></DIV></TD></TR></T></TABLE>
MercAdvisor Oct 11, 2004 07:31 PM
does the vehicle have a 3.0 sohc or the dohc?Edited by: MercAdvisor
Lenny Oct 19, 2004 05:40 PM
Check core and HVAC regulator. Hoses being warm could be water or ti could be air. If only air,the core will not transfer the heat.
Lenny.[img]smileys/smiley16.gif[/img]
ugothim Feb 2, 2005 04:59 PM
are hoses warm both going in AND coming out ? if one is warm and the other is cold then you have a bad heater control valve..which i hate to tell you is located inside of the heater core enclosure..which is a very time consuming
Windzer Feb 7, 2005 11:39 PM
Check vacum lines that control the
place the heat comes out such as
floor,def,both, might be stuck on ac
in the hvac behind the glove box.
Lenny Feb 10, 2005 04:37 PM
I have found that it is not the vacuumlines themselves but a faulty "block" that the vacuum lines are controlled by.Replace the block and you should be fine.
