slymer |
11-18-2008 04:25 PM |
gaining access to the retractors should be just removing the rear seat and the side moldings (if shoulder belts). To remove the rear seat, simply lift up on it until it pops free (there may be one bolt at each end near the doors holding it down. I''m guessing since I''ve never actually worked on a sable wagon, but I figure it''s the same as the 99 sedan.) The seat belt retractors should be bolted to the floor. I don''t know if any have some kind of reset switch, or whether you would be able to take the cover apart and see if some random piece of clitter is jamming the mechanism, but you should be able to remove the faulty ones easily after removing the seat.
