2001 Sable won't start
Old Mar 30, 2020 | 05:59 PM
Laura_Wade's Avatar
Default 2001 Sable won't start
My 2001 sable has been in storage since may 2019. It ran perfectly when parked. Now it only clicks when trying to start. Battery fully charged and jumped doesn't help. Where else can I look?
Old Apr 12, 2020 | 07:27 AM
raski's Avatar
Have the battery load tested.Unless you kept a trickle charger on it, it is likely shot. Go over and clean ALL connections on the plus side wiring and all grounds including at the engine block. Looks good doesn't mean anything if the connection isn't taken off and cleaned. You can use a volt meter and check for energy at the starter with a helper to turn the key.Still no crank after servicing the connections and battery, remove and get the starter tested.Hopefully,you have solved the problem by now. Let us know.
01marquis
Oct 10, 2011 09:59 PM
steve~p
Mar 26, 2010 05:04 PM
mcafferty
Feb 3, 2009 05:01 AM
djs297
May 9, 2006 06:04 PM
draint
Feb 6, 2006 09:41 AM
