2003 Sable Blower Resistor
Hello,
We just bought a 2003 Sable. The car is in great shape and only 40K miles. The only issue is the blower on the AC/Heater. It only blows on high speed. I have done some research on this, and found that these Sables have an issue with water getting into the motor and the resistor, causing problems. I am trying to replace the resistor. Not being a very experienced mechanic I had problems locating it, but I seem to have found it under the glove box. I put up a picture of it here: http://picasaweb.google.com/rjkardo/DropBox# The problem I have having now is getting it out. I disconnected the cables and put a ratchet on the 2 bolts. But the won't come out. They turn, but never seem to come out. Seriously, I turned one for 10 minutes and it is the same as before. I know the bolt is turning but nothing happens. Without laughing at me, can anyone tell me what is wrong? Rod |
the plastic the screws are set in is probably stripped out. you may have to pull on the harness part of it while you unscrew it.
Originally Posted by slymer
(Post 12324)
Thank you, I will try that in the morning. Rod |
(Post 12324)
no, I had oatmeal.
If u have no luck there and don't have climate control, may be the low-speed fan switch.
Originally Posted by conan312
(Post 12348)
Other comments in other threads lead me to believe that there could be further problems if the water leak is still there, but I think this car has been corrected already. But I will keep an eye on it and see what happens. Thanks again, Rod |
| All times are GMT -5. The time now is 05:10 AM. |
