I just aquired a Sable at a auction and it has a transmission leak, but I can't seem to find the dip stick to check if the fluid is low. I'm not a auto mechanic, but I can fix most minor problems. Everything else is where it can be found but not the transmission dip stick.
Well look on the transaxle side and if you can't find the dip stick then maybe its missing. So in that case look for a hole in the top of the transaxle.
Thanks. I found it hiding behind the plastic shroud against the fire wall in my search. Thanks for the help.
