94 Sable gear shift won’t shift from Park
Old 05-31-2005, 09:14 PM
rekab3's Avatar
I have a 94 Sable that keeps blowing fuses which causes the brake lights not to light and the gear shift will not shift from Park to Drive. I have replaced the brake switch and it worked for a short period and then blew the fuse again. Any suggestions fro where to go from here would be helpful.
Old 06-01-2005, 06:57 PM
cctxfish's Avatar
Look for pinched wires maybe in trunk. You might have a bulb that is causing high current, try replacing all brake light bulbs if you can't find short in wireing harness. good luck
Sharper
10-03-2011 09:38 AM
dave59330
02-16-2009 08:45 PM
CasaLambretta
01-21-2009 06:05 PM
meatball31
01-17-2008 09:38 PM
Cablekid
02-20-2007 06:49 AM
Quick Reply: 94 Sable gear shift won’t shift from Park
