94 Sable gear shift won’t shift from Park
Old May 31, 2005 | 09:14 PM
rekab3's Avatar
I have a 94 Sable that keeps blowing fuses which causes the brake lights not to light and the gear shift will not shift from Park to Drive. I have replaced the brake switch and it worked for a short period and then blew the fuse again. Any suggestions fro where to go from here would be helpful.
Old Jun 1, 2005 | 06:57 PM
cctxfish's Avatar
Look for pinched wires maybe in trunk. You might have a bulb that is causing high current, try replacing all brake light bulbs if you can't find short in wireing harness. good luck
Sharper
Oct 3, 2011 09:38 AM
dave59330
Feb 16, 2009 08:45 PM
CasaLambretta
Jan 21, 2009 06:05 PM
meatball31
Jan 17, 2008 09:38 PM
Cablekid
Feb 20, 2007 06:49 AM
