Hey guys, hoping someone out there has some knowledge as per my question... Got a 94 Sable here, power seat motor won't go forward or back... any other direction is fine... The seat has been set closest to the wheel and I'd like to move it back... Any way to do this manually .. is there a leaver of some sorts... if I cut the power to the motor will it slide on the track... Would really like to avoid having to bring it in for such a minor issue. |
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> It may be the fuse. Check under the steering wheel (next to the brake pedal) for a blown fuse. |
| All times are GMT -5. The time now is 06:39 AM. |
