-   -   97 Sable GS starting trouble (https://www.mercuryforum.com/forum/sable-13/97-sable-gs-starting-trouble-49/)
pastorchuck Dec 29, 2004 01:06 AM
When the car is cold it starts right up, but after it has been driven for a while it becomes difficult to start a few minutes after it has been shut off. I have recently replaced the spark plugs and wires. Might it be the oxygen censor?
Thanks
Chuck
MercAdvisor Jan 2, 2005 04:57 PM
Thats a difficult one to help with, There are so many reasons that could cause that problem from electrical to mechanical you may want to havea properly trained professional take a look at that one..
ugothim Feb 2, 2005 04:48 PM
if it drags or the starter turns slowly check for a bad starter they tend to drag when hot. if it spins over at normal speed ..then check the ignition control module..[img]smileys/smiley1.gif[/img]
Windzer Feb 7, 2005 11:46 PM
Sounds like your starter turns but the
car dont start ? If so check destrebuter
or the coil and check connections .
then go the a Professional like MercAdvisor
said .
Lenny Feb 10, 2005 04:31 PM
Check to see if you have a UIM leak (upper intake manifold),only shows when warm due to air press/and temp.
