sinned1 |
02-27-2008 11:35 PM |
I'm back to an old problem. The sable is spurting coolant out the cap. The only time it does this is when you come to a stop after running a while. The gauge never gets over halfway, but you can hear the coolant chug everytime I shut it off. I have replaced all the usual suspects, including the cap and thermostat, hoses, water pump,rotted the radiator twice and back flushed the heater core. The engine runs great and I get no smoke as you would if the heads were burnt. It is possible the heads are warped and this is causing the problem? The only thing I have done since last time this happened was to replace thecataylic convertors to get it inspected.Any help will be appreciated.
