Could somebody tell me if I can change the air/fuel mixture on my '97 24V 3.0L Sable. At idle all you can smell is gas from the tail pipes. |
It's supposed to be plugged from the factory. Try cleaning your mass air meter, changing your fuel filter, and cleaning your idle air controll valve.
already did the fuel filter with a tune up that I hoped would cure the the richness. try the others and let you know. thanks!
