-   -   Any advise on replacing water pump an alt (https://www.mercuryforum.com/forum/sable-13/any-advise-n-replacing-water-pump-alt-1596/)
rstrunk Feb 20, 2008 12:18 AM
On a 96 Sable with 3.0 duretec? Just bpought the car today. I was told be the seller it needs an alternator. I se it is buried and might be a tough job. But while driving it home about 20 miles it started leaking coolant out of what appears to be the water pump area. Is this a very difficult back yard mechanic fix? If so any ball park figures of how much a shop will charge to fix these teo things? Thanks in advance for any advise.
< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">uacct = "UA-939292-45";
urchinTracker();
Edited by: rstrunk
sinned1 Feb 21, 2008 02:25 PM
The alternator is pricey, but get a rebuilt one. The hardest part of changing it out is getting the belt off. It takes a 15 mm which are hard to find. Might want to change the idler pulley bearing while you have it off. Mine froze up and broke the belt.
< =text/>
_uacct = "UA-939292-45";
urchinTracker();
