blower motor quit
Yes. I can help you out.
This is a noun in the English dictionary. Relay..1. meaning a device that controls the blower motor. 2. has heat fins and controls the blower motor.
in Greek it is also a noun. spelledREEeLAYe. this is where we get the word relay from. it also means the same thing. a heat fin that relays to the blower motor.
Hey wise ***, if you run a wire from your battery to your blower motor to test it and it bursts into flames let me know and I will buy you a new one. A relay does not control the blower motor. That would be the high or low speed fan switch and electricity. If you would like to hook your fan motor up, while the car is running, with a bad voltage regulator, then we can talk spent relays and maybe a fried blower motor. I''m done with you newbies.
