-   -   blower motor quit (https://www.mercuryforum.com/forum/sable-13/blower-motor-quit-1919/)
1996 green sab Aug 4, 2008 08:11 AM
the fan blower was constantly on , now it quit working, i checked fuses and changed relay still not working,
conan312 Aug 5, 2008 12:56 PM
Fan switch sounds like it quit awhile ago.
1996 green sab Aug 11, 2008 06:43 AM
i changed that blower control , everything is working fine now,
conan312 Aug 11, 2008 10:51 AM
Blower control?
1996 green sab Aug 11, 2008 08:49 PM
that thing that the blower plugs into it has a heat fins on it
jason sereiko Aug 12, 2008 03:27 PM
you have to be specific for conan and spell correctly or he questions you with ? marks after everything he says.
conan312 Aug 12, 2008 07:13 PM
Glad you got it figured out.
1996 green sab Aug 12, 2008 07:14 PM
does anyone know the correct name and spelling for that part? i don''t want to upset conan
jason sereiko Aug 12, 2008 11:18 PM
Yes. I can help you out.
This is a noun in the English dictionary. Relay..1. meaning a device that controls the blower motor. 2. has heat fins and controls the blower motor.
in Greek it is also a noun. spelledREEeLAYe. this is where we get the word relay from. it also means the same thing. a heat fin that relays to the blower motor.
conan312 Aug 13, 2008 04:06 AM
Hey wise ass, if you run a wire from your battery to your blower motor to test it and it bursts into flames let me know and I will buy you a new one. A relay does not control the blower motor. That would be the high or low speed fan switch and electricity. If you would like to hook your fan motor up, while the car is running, with a bad voltage regulator, then we can talk spent relays and maybe a fried blower motor. I''m done with you newbies.
