Brake warning light has everyone confused - help...
Old Jul 27, 2015 | 09:46 PM
campervan12000's Avatar
Default Brake warning light has everyone confused - help...
2002 Mercury Sable LS 74k
Over the last couple of days my red brake emergency light has been coming on. In the dark there is a trace of the ABS light which glows brighter when the brake is applied. The mechanics have tested for codes, checked the reservoir sensor, for leaks etc. but all checks out OK. Any ideas. The brakes are fine as is the emergency brake and sensor.
Thank you....
Old Jan 12, 2021 | 11:12 AM
Andrewski's Avatar
Default Lights on hard braking '03 Grand Marquis
Wish I could help with your issue. My '03 Grand Marquis 'brake warning' light comes on when hard braking at highway speed, then go out when pedal lifted.
This is the same indicator that indicates that the 'park brake' is engaged.
Warning light does not illuminate under normal braking.
Fluid at normal level, no leaks, and braking deceleration seems normal.
I will return here if I find any info. on this,
Mercuryowner1
Oct 2, 2013 08:50 PM
Russell
Jan 29, 2012 11:14 PM
tandtb
Apr 1, 2009 08:59 PM
Izzy
Nov 24, 2008 12:47 AM
gibs107
Oct 20, 2006 06:40 PM
