-   -   CEL after cleaning injectors (https://www.mercuryforum.com/forum/sable-13/cel-after-cleaning-injectors-989/)
troppus8 Mar 22, 2007 02:17 AM
Car was running great, no problems. Got a routine oil change and was talked into cleaning the fuel injectors. After about 5 miles from leaving the lube shop, my Check Engine Light comes on. Man, why didn't I leave well enough alone.......
I have to believe its because of the injector cleaning. I checked for loose vacuum hoses...etc, but nothing found. What the heck? Anyone run into same issue after this procedure, and what did you do to correct it?
Thanks.
troppus8 Mar 23, 2007 02:29 AM
Well, it appears whatever caused the CEL to come on, is now fixed. Light has turned off and has stayed off. Weird. Maybe the system didn't like the injectors to be cleaned..lol
