-   -   Duratec 30 O2 Sensors (https://www.mercuryforum.com/forum/sable-13/duratec-30-o2-sensors-1701/)
RogerB34 Apr 14, 2008 07:29 PM
The sensors are consumables meaning replacement.
The front sensor is accessible. The rear (Bank 2) is buried. Ford shop manual says to remove and that's it. I can see the green plug wire but not the sensor.
Is the Bank 2 sensor accessible from underneath the car?Or does the Uppper Intake Manifold require removal?
RogerB34 Apr 19, 2008 07:27 PM
The answer is that the upper air intake manifold must be removed to gain access to the Bank 2 Upstream O2 sensor. Should be replaced when plugs are replaced at 100k. RockAuto BoshOEM for $38 each.Of the four, the Upstreams are most important.
