Electronic dash problem
My 1992 Sable LS wagon has a short in the circuit that supplies power to the electronic dash.
The fuse that blows when I turn on the car is a 15 amp fuse that protects the following circuits: • Electronic cluster • Rear Window Defroster Switch • Electronic Flasher • Backup Lamps • Heated EGO • Illuminated/Keyless Entry Module • Brake Interlock Solenoid. The fuse is the 15 Amp fuse that has the red glow I am trying to track down the problem. Any likely culprits? Any method for starting? Thanks, Neal |
| All times are GMT -5. The time now is 09:05 AM. |
