-   -   Lean bank codes (https://www.mercuryforum.com/forum/sable-13/lean-bank-codes-5761/)
jarettb Aug 26, 2011 11:59 PM
Lean bank codes
It says both banks are running lean essply bank 1, Is there suppose to be a air sound underneith the throttle body or do I have a vaccum leak.
Ontop of the two lean codes it says both oxygen sensors are not cycling and long fuel trim is maxed at 25.
I have a fuel pressure tester and a vaccum guage.
What could be wrong, and what should I do?
jarettb Aug 29, 2011 01:00 AM
Got it the pcv hose that lets fresh air into the crankcase split right under the throtle body.
