HI there [img]smileys/smiley7.gif[/img]All of a sudden my remote does not open anything! [img]smileys/smiley7.gif[/img]Not my locks, not my "panic alarm"...nothing! Changed the battery in it, but it made no difference. Also, my auto lock when in gear no longer works...anybody have any suggestions? By the way, its all of the remotes, not just 1.Thanks[img]smileys/smiley1.gif[/img] |
It sounds like the signal got reset somehow. I would try to reprogram the remotes. It's not a big deal. You will need both remotes and the ignition key. Stick the key in the ignition and turn the swtich on and off 8 times (I think). The doors will lock and unlock (key should end in the on position. Next you will need to hit the lock button on both remotes and turn the car off. See if that doesn't work.
