| sablebomb |
Jul 14, 2011 09:08 AM |
No running lights
I own a 1999 Sable. I am having trouble with the running lights. I used to have trouble with the headlights not shutting off. I replaced the light switch itself and that problem was solved. Now I don't have any running lights and half the dash lights are not working. I checked the fuse box under the dash (not easy to get in there) and checked fuses that I thought might be related (5 amp switch illum, 5 amp tail lamps and the 5 amp instr illum). All seem fine. I even checked the fuses under the hood and nothing looks obvious. I know its possible for a bulb to be burned out, but all of them at the same time is unlikely. Any ideas on how to trouble shoot this problem. Maybe I need to look at a different fuse?
Have a WONDERFUL DAY.
