Hi, I have a Sable LS 01'. I wanted to remove the radio and add a Sirius transmitter to reduce the amount of static I encounter. Now I have the DIN pins or removal pins that are "U" shaped and I've inserted them into the holes. I have pressed each in the outward direction and tried to remove the radio to no avail. What am I doing wrong? Do I need to remove the trim that surrounds the radio ? I haven't been to forceful as I do not want to risk breaking anything. I have asked around but have not found much help. Thanks in advance.
-Glenn < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45"; urchinTracker(); </> |
The trim around the stereo should pop right off. Pull from two opposite sides at once so you don't snap it. But look for any small trim screws along the way. Let me know.
I got it. After finally getting it out I realized the antenna plug is in the back. Well, at least it was a learning experience. < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
| All times are GMT -5. The time now is 04:42 AM. |
