Rake and pinion- 1998 Sable LX
3 Attachment(s)
Any help will be appreciated........https://www.mercuryforum.com/forum/a...1&d=1290615203, https://www.mercuryforum.com/forum/a...1&d=1290615214, https://www.mercuryforum.com/forum/a...1&d=1290615226
you trying to get it out? if so you have to loosen the front subframe bolts and take out the rear ones completely.
do i have to take the R&P out to fix the bent rod? and are there any easy ways out?
No if you can get a inner tie rod removal kit. if you cant get your hands on one then you will have to remove it because it in a hard place to get any tools on it and most cars have thread locker on them so its going to be hard with the tool
Considering the sf asian escort above mentioned, we can come to the conclusion that to give up wisely is a kind of more sf asian escorts mature life attitude. Though giving up sf escort sometimes is painful and costly,in the long run sf escorts what we gain will definitely far out weight what we lose.
wtf??:confused:
jonusb4 is just spamming the forum with links to adult websites.
| All times are GMT -5. The time now is 03:19 AM. |
