Serpentine Drive belt squeaks
Old Jun 25, 2013 | 04:38 PM
mrrotary's Avatar
Talking Serpentine Drive belt squeaks
I have seen this listed on several forums - I have a 1994 Sable with 194,000 miles and recently had a serpentine belt squeak which I dived into because I could not get it to stop. Ford Dealer said it was my water pump. HOWEVER I went simple first - thank god for "lifetime" repair parts from AutoZone! I changed the guild pulley, the belt, then the belt tensioner, water pump, power steering and finally the alternator and NOTHING WORKED stilled had a high pitched squeak. (Note I did find a small water leak and while you are near water pump ALWAYS change out the 4" of hose buried behind all of these parts.)
I went back and changed the tensioner again and DISCOVERED the bolt provided was a bit loose without the tensioner. SOLUTION - I put some RTB on the bolt and tightened to specs and corrected the whole problem. Hope this helps many of you save all the above work.
searchlight4759
Aug 3, 2012 11:27 PM
trailhand
May 19, 2010 01:08 AM
bkatzman
Nov 21, 2009 04:32 AM
misteral
May 2, 2009 05:21 PM
rickmichaels
Apr 19, 2006 12:04 AM
