Any one ever attempt at turning your sable into a manual stick shift? im flat out sick of these faulty trannys. does anyone know what other models used the same layout, so i could find a compatible standard tranny? Its a 96 sable ls
var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--></>alot offord SHO's came with 5-speeds. you can start there. maybe have to change the bell housing. parts for those two car are very compatible, as long as the years and body styles are the same. good luck and let me know. < => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> Edited by: conan312 |
