we bought it w/o a trunk key and the trunk puller is locked what should i do
does the back seat fold down? if so see if there is a saftey release lever. what is a trunk puller?
what i call the trunk puller is the lever beside the driver seat
if it has a lever, than maybe you can unhook the cable and pull on it with Vise-Grips.
I had the same problem. Luckily, I know the code to open the car with the buttons on the door, so that works. If you have that, you enter the code and then press 5 right after that. Still, I wanted the lever to work, so I drilled out the lock next to the lever, and now it works. Try that. Edited by: cafeconleche |
