-   -   turn signals won’t blink (https://www.mercuryforum.com/forum/sable-13/turn-signals-wnt-blink-1007/)
Cathy Kirkes Apr 14, 2007 11:37 PM
Changed the bulbs, fuses and flasher. Not blinking on the dash eather. Any suggestions?
prafopi17 Apr 19, 2007 08:00 AM
it could that you have a poor grounding system. it would be best if you would clean all connection. it could also because of a burned bulb, if that is the case it should be replaced. check also the wirings, see to it that it is properly wired.
