Well this is the low down 2256.20 wow but this is the list 1 assembly set-ls-w/.070 intermediate steels(b) 217.11 1 filter-2nd design(b)==================15. 41 1 band-overdrive(b)= ================ 15.83 1 band overdrive(b) ?================= 20.03 13 fluid(b) ;  ; ; ; ; ;==================== 68.25 7.5 labor(rr)(b) =====================525.00 8.4 labor(r)(b) ;===================== 588.00 1 torque converter====================3 29.00 1 chain-drive assembly(chainstre tched)====99.43 1 piston-forward clutch(was cracked)=======21.00 1 planet-ary(was comming apart)=========55.00 1 solenoid-L/u (milege)=========51.00 1 solenoid-pressure control  ; ; ; ; ;"======== 51.00 3 solenoid-shift ;  ; ; ; ; ;" ;  ; ; ; ; ;=====136.08 1 sprag clutch-low clutch sprag ;  ; ; ; ; ;======45.00 1 roller clutch-direct clutch roller ;  ; ; ; ; ;======31.00 1 vb kit-shift kit-transgo(updated Vbody lubeholes)==66.00 tax====================================61. 00 cupone (100.00)cupon from web== -139.00 total parts========================= ==1221.14 labor ;  ; ; ; ;==========================974.00 total ;  ; ; ; ; ========================== 2256.20Edited by: Windzer |
Well $2256.20 and its fixed . |
you could of got four trannies from the junkyard. Hell you could bought a whole other Sable. $2200.00 is crazy.
| All times are GMT -5. The time now is 07:08 AM. |
