Suspension Talk about your suspension within...
gm rear air springs
Old Dec 6, 2008 | 06:44 AM
ramit98's Avatar
hi i got a 2003 GM and the rear seems be really high compaired to the front always feel like i am driving down hill ..is there an adjustment on the sensor on the rear end?
Old Dec 8, 2008 | 08:23 PM
good question. the only thing I can find in the chiltons I have (which tops out at 1998) is that there is a on/off switch for the air suspension. I would suspect that yours has had the switch turned off or some valve is stuck on the rear springs. You may have to have a dealer point out where the switch is. I can''t find any adjustments anywhere. there must be a controller for the system somewhere and a dealer should be able to point that out to you. I say should because not all dealers have knowledgeable staff. Good luck.
Old Dec 15, 2008 | 10:44 AM
ramit98's Avatar
well figred it out .not the rear air system at all the front coils are weak ..better then rears i guess ..does any one know if 2003 crown vic /taxi/police intercepter springs fit ?
Old Dec 15, 2008 | 12:35 PM
anything from the same model year should cross over between any model crown victoria or grand marquis. The exceptions are the taxi/interceptor platforms. the springs should fit though. They may ride a bit higher from what I''ve read. it''s definitely worth a look at summitracing.com and other sites that sell springs and suspension parts to get a good idea what your in for. also, the shock absorbers do supply some extra lift and that may actually be part of the problem as well.
maddawg
Sep 2, 2015 05:08 PM
Julydays
May 9, 2010 03:38 PM
lalakelley
Apr 28, 2008 08:50 AM
lkmfcars
Feb 7, 2007 07:42 PM
2000_Mount
Jul 22, 2005 04:06 AM
